Activity › Forums › Adobe After Effects › Automating a time lapse in AE?
  • Automating a time lapse in AE?
    Posted by Blake Porter on August 3, 2010 at 11:52 pm
    I often create time lapses’ in AE 7.0 using still photos.
    I’m hoping this can be done smarter than I’ve been doing it.
    Typically, I import 200 stills, shorten all lengths to 5 frames and then move them all by hand so they play in succession. This takes along time (duh).
    I did search for tips, but didn’t see anything exactly like this… Any pointers would be very welcome
    Blake Porter replied 16 years, 2 months ago 2 Members · 2 Replies
  • Walter Soyka
    August 4, 2010 at 12:32 am
    [Blake Porter] “I often create time lapses’ in AE 7.0 using still photos.
    Typically, I import 200 stills, shorten all lengths to 5 frames and then move them all by hand so they play in succession. This takes along time (duh).”
    I’d import the footage as an image sequence, instead of as a series of individual images.
    You can then interpret the footage at a different frame rate before dropping it into a comp for render. For example, if you were working in an NTSC comp (at 29.97 fps), you could re-interpret the image sequence at 6 fps to get each still on-screen for 5 frames.
    Walter Soyka
  • Blake Porter
    August 4, 2010 at 1:15 am
    Thank you! I will try this.
