Activity › Forums › Adobe After Effects › Automating a rendering process
  • Automating a rendering process
    Posted by Connor Evans on March 2, 2021 at 4:17 pm
    I’ve built a template animation to advertise a webinar and it can come in 4 different colour schemes depending on a drop down control, rather than rendering these one at a time is there a way to make a script to render the comp with the first item in the drop down selected, then the second, third, fouth etc..
    Connor Evans replied 5 years, 6 months ago 2 Members · 2 Replies
  • Kevin Camp
    March 2, 2021 at 5:56 pm
    You probably can do it with a script, but I would set it up with a simple expression that uses a number from the comp name to drive keyframe changes on the dropdown… Sounds more complicated than it is.
    Try this:
    Change you comp name to have a 1 at the end of it (like “My Comp 1”) and add a keyframe for the first menu selection (time doesn’t matter).
    Then add a new keyframe for the second menu selection and continue doing the same for all menu selections. Again the time doesn’t matter, it could be one frame or one second…
    Then add this expression to the dropdown’s ‘menu’ property:
    n = thisComp.name ;
    n[ n.length - 1 ]
    at this point, if you comp has a ‘1’ at the end of the name, the first menu item should be selected no matter what keyframe you are on.
    Now just duplicate the comp so you have 4 of them. Each comp should now have a menu selection set to the number at the end of the comp name.
    Add them to the render queue and render.
  • Connor Evans
    March 3, 2021 at 10:25 am
    Thanks, thats a smart little work around, i was trying to learn Extendscript instead
