Activity › Forums › DaVinci Resolve › Automatically match master timeline with media pool
  • Automatically match master timeline with media pool
    Posted by Eric Chase on April 8, 2014 at 7:24 pm
    (Not sure if this was covered, I’m using the latest DR10.1.3)
    Remember Resolve always had the master timeline, that when you changed on shot, the rest of the shots from that media file was colored?
    Before importing footage or a timeline, I clicked on “Automatically match master timeline with media pool” then imported my XML.
    I got all my shots in, but when i color 1 shot, the others from that clip don’t have the grade applied.
    What am I missing?
    Juan Salvo replied 12 years, 5 months ago 6 Members · 9 Replies
  • 9 Replies
  • Eric Johnson
    April 8, 2014 at 7:50 pm
    Pretty sure Resolve still defaults to “Local” grading, so you need to set you timelines to use “Remote” grading.
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/ebjohnson/colorreel
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Eric Chase
    April 8, 2014 at 8:36 pm
    If I uncheck “use local version for new clips in timeline” nothing changes. I still need to apply a grade to every edit.
  • Eric Johnson
    April 8, 2014 at 9:03 pm
    If you right click the timeline, may need all clips selected, in the Color Page, there is an option to use Remote/Local grades.
    The check mark you are referring to only effects NEW media in the project… not new grades.
    eric b johnson
  • Prathvish Hegde
    April 9, 2014 at 6:25 am
    hi Eric,
    there is an option to copy remote grades to local which is helpful if you have graded the mastertimeline.
    prathvish hegde
    colorist
    (DaVinci Resolve and 2Kplus)
    https://www.youtube.com/playlist?list=PLRPJQ3fIEoojI3JMa4rHKb9gqq8VeIZ81
  • Paul Provost
    April 9, 2014 at 3:50 pm
    I would uncheck use local grades when importing
    Check Automatically match to master timeline
    Check auto save every twenty or whatever for good measure
    Save that as a user preset so it always does this
    Start a new project and import XML
    Color trace any grades over if needed
    And the newest is 10.1.4
    http://www.filmandtvcolor.com | colorist | Los Angeles, CA
    Twitter: @4kfinish
  • Eric Chase
    April 11, 2014 at 12:53 am
    Thanks, that worked!
    Now that I have the timeline changing all at once, what would be the switch to make once clip to color separately from the rest of the takes?
  • Paul Provost
    April 11, 2014 at 1:14 am
    right click on a clip thumbnail and chose make new version / remote
    then download the brand new manual Feb 2014 from support page and read it
    cover to cover
    twice
    Twitter: @4kfinish
  • Marc Wielage
    April 11, 2014 at 10:40 am
    [Paul Provost] “then download the brand new manual Feb 2014 from support page and read it cover to cover… twice”
    Very wise advice.
  • Juan Salvo
    April 11, 2014 at 1:03 pm
    He doesn’t call himself “the oracle” for nothing. 😉
    https://JuanSalvo.com
    https://theColourSpace.com
