Activity Forums VEGAS Pro Automatically create 100 files in Sony Vegas
  • Automatically create 100 files in Sony Vegas
    Posted by Fritz Henle on June 11, 2017 at 7:29 pm
    I do have around 100 cuts in one of my timelines in Sony Vegas. I want Sony Vegas to create a single file for the video material between two cuts. So that I don’t have to mark everything separately to get my 100 files.
    Thanks for you help!
    Best wishes,
    Fritz
    David Eon replied 9 years, 1 month ago 3 Members · 3 Replies
  • Fritz Henle
    June 14, 2017 at 7:11 am
    does nobody know how to do this?
  • Aaron Star
    June 17, 2017 at 8:24 pm
    This topic is covered over here:
    https://www.vegascreativesoftware.info/us/forum/batch-render-regions-to-filenames–94424/
    Basically you create regions, then run a script that will render each region to a new file name.
    You can custom name your regions and that name will be the new file name.
    There is another script that will auto insert regions at cuts.
    Details Editor window is your friend to cut and paste details you want into region names.
  • David Eon
    July 15, 2017 at 8:44 am
    If I’m reading this right, you may also want to look at Vegasaur> Keep Inside Regions. It can Isolate only the regions and delete everything else. Then use Vegasaur>Close Gaps to create one continuous video from all of your isolated cuts. I hope this helps. Thanks!
    DavidEon
