Activity Forums Adobe After Effects Expressions Automatically Centre Dynamic Precomp with an Expression
  • Automatically Centre Dynamic Precomp with an Expression
    Posted by Henry Gaunt on January 17, 2017 at 4:11 am
    Hello.
    I’ve done a lot of reading and tried a lot of expressions, but have yet to get this to work.
    I have a pre comp of text which sits within my sequence. This pre comp is automatically filled in by an excel spreadsheet using CompsFromSpreadsheet.
    This pre comp contains 6 different text layers that displays on a single line.
    In the main sequence, regardless of this pre comps width, I’d like it to automatically centre on the vertical.
    At the moment it’s collapsed and I centre it by using the align tool. But there are hundreds of comps that are automatically created and I’m hoping to automate this.
    Is this possible?
    Thank you
    Henry
    Henry Gaunt replied 9 years, 8 months ago 1 Member · 1 Reply
  • Henry Gaunt
    January 17, 2017 at 6:41 am
    I should note, the fundamental action I need to do is to…
    Is there an expression version of the Align Panel’s Horizontal Centre Alignment which will execute once the layer has been created?
