Activity › Forums › Adobe After Effects › Automatically center a layer
Posted by Mike Brassee on August 12, 2020 at 10:29 amHello,
I’ve made a countdown timer in after effects.
But because the with of the numbers isn’t the same across them all, the countdown changes length.
Thus it looks like the countdown isn’t centered anymore.
Is there a way to automatically center the countdown during it’s run?Mike Brassee replied 6 years, 1 month ago 2 Members · 4 Replies -
Walter Soyka
August 12, 2020 at 7:43 pmThere are a few different ways to make a countdown. Which technique did you use?
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Mike Brassee
August 13, 2020 at 7:51 amI’ve used the following code:
rateOfSpeed=1;
clockStartTime = thisComp.layer("Timer Duration").effect("Slider Control")("Slider")*60;clockTimeNumber = Math.floor(clockStartTime - rateOfSpeed*time);
function addZero(n) {
return (n < 10) ? "0" + n : n;
}minutes = Math.floor(clockTimeNumber/60);
seconds = clockTimeNumber%60;if (clockStartTime > 0 && time < clockStartTime) {
addZero(minutes) + ":" + addZero(seconds);
} else {
"00:00";
}The problem however, is that my font doesn’t have the same with for all the characters.
Therefor the countdown goes off center when counting down. -
Walter Soyka
August 13, 2020 at 1:12 pmOf course, you can use a mono-spaced font.
If that won’t work for your design, I’d suggest using Numbers effect. Set it to Timecode, untick the “Proportional spacing” option, time-reverse the layer it to make it count down instead of count up, and mask off what you don’t need.
Walter Soyka
