Activity › Forums › Maxon Cinema 4D › Automatically assign parent layer to all child objects?
Posted by John Willard on April 28, 2016 at 2:28 pmI have a parent node with lots of child objects. All child objects must belong to the same layer as the parent node. This can be achieved by ctrl+dragging the layer to the parent node. However, is there way that whenever I drop new objects below the parent node, that they are *automatically* assigned to the parent layer?
Thomas Williams replied 8 years ago 5 Members · 6 Replies -
Brian Jones
April 28, 2016 at 3:17 pmif you click and hold on a layer icon in the OM the cursor turns into a paint brush and you can ‘paint’ the layer to other objects. (at least in 17, don’t know when that behaviour started).
John Willard
April 28, 2016 at 3:53 pmYes, that’s correct, but when there are lots of objects and children, then that procedure is too time consuming.
Alan Farkas
April 28, 2016 at 5:02 pmGreat Q for a thread. Can I add this to it:
If I Solo a Layer, and then Group a handful of objects (children of a Parent belonging to the layer even), the new Null/Group is no longer part of the Layer. Same goes if I create a MoInstance.
This is extremely time-consuming and inefficient in a workflow. Is there a workaround for this?
Hope it makes sense to have piggy-backed this thread, thx
John Willard
May 1, 2016 at 6:43 amI’ve found the solution to my problem, and that is to create an Xpresso tag and place it on the parent node (e.g. called “GEOMETRY” which is set to the “GEOMETRY” layer). In the Xpresso editor I’ve place two nodes, an object node and a python node. The object node outputs are Object and Layer. The python node inputs are inObject and inLayer. In the python node code I wrote this:
#This script will set the layer to every
#child object to the same layer as the
#parent object (the object which contains
#the xpresso tag)import c4d
def SetChildLayers(inObj):
for child in inObj.GetChildren():
child.SetLayerObject(inLayer)
SetChildLayers(child) #recursivedef main():
SetChildLayers(inObject)
Now, any time I place objects under the GEOMETRY node, their layers will automatically be set to the GEOMETRY layer. This works perfectly and is a real time saver!
Lars Rietkerk
March 15, 2017 at 2:22 pmThank you John!
I’ve been trying to figure out your script. But I coudn’t get inObject and inLayer to show up on my python node. For anyone with the same problem: link object and layer to the python node ( which will get you Input3 and Input 4 ). Now put in this script and you should be good to go. Test by dragging something on your object with the xpresso tag.
child.SetLayerObject(Input4)
SetChildLayers(Input3) -
Thomas Williams
September 18, 2018 at 10:53 pmIn the Object Inspector window, select the first child object, then hold shift and select last child object. Children are selected and hilighted. In the Attributes Window below, in Layer pane, click the little arrow to the right of the pane and choose > Add to Layer.
