Activity Forums Adobe After Effects Automatic Z-Depth from JPG?
  • Automatic Z-Depth from JPG?
    Posted by Lucas Schwartz on February 24, 2019 at 5:57 pm
    Hello All,
    I was just wondering if there is such a software exists that can create an automatic Z-Depth map from a common JPG please?
    If there is no such software currently available on the market what would be the easiest way to quickly create complex z-depth maps from 2d images?
    Best regards,
    Lucas
    Lucas Schwartz replied 7 years, 6 months ago 2 Members · 2 Replies
  • Mark Whitney
    February 24, 2019 at 11:40 pm
    Yes, but not for sequences at least yet. Not particularly easy to find either as it’s just one aspect of a plug-in for Photoshop and Affinity called Tapaz Labs Lens Effects
    https://topazlabs.com/lens-effects/
    They also make Topaz Studio just to confuse things initially. Some of their products are stand-alones, some are plug-ins, & some just for Studio with crossover versions from the others. Got that?
    Anyway, in Lens Effects, they’ve a Bokeh Lab.
    Take a look at these vids & it’ll make sense.
    https://www.youtube.com/user/topazlabs/search?query=Lens+Effects
    Main point is, you can export the resulting depth map.
  • Lucas Schwartz
    February 28, 2019 at 10:38 am
    Hello Sir,
    Thank you for your response. I have spent a long time looking for a solution to create automatic depth maps. The suggested “Topaz lab solution” will work really well. I also have had it installed as a photoshop plugin already.
    I just watched the suggested tutorial also which was helpful to explain how to use the plugin.
    Once more thank you for the excellent tip!
    Best regards,
    Lucas
