Activity › Forums › Adobe After Effects › Automatic resizing in After Effects CS6
  • Automatic resizing in After Effects CS6
    Posted by Marko Ristić on June 29, 2014 at 8:40 am
    I have a composition which is 1920x 1080 and i want to import a .mp4 footage that is 1440×1080.Every time i import it Ae resize the footage to 1920×1080 sets the scale of the footage to 100% .Is there any way to turn that feature off?
    Thank you!! 🙂
    Marko Ristić replied 12 years, 3 months ago 2 Members · 2 Replies
  • Erik Waluska
    June 29, 2014 at 5:26 pm
    1440×1080 is supposed to be stretched to 1920×1080 because that’s the size it should be displayed. The difference is the pixel aspect ratio: 1920×1080 uses square pixels with a pixel aspect ratio of 1.0; 1440×1080 uses rectangular pixels so its aspect ratio is 1.333.
    If, for some reason you actually do want to change the pixel aspect ratio of the footage, you can right-click the clip in the project window and go to interpret footage > main and change the “pixel aspect ratio” setting at the bottom of the window.
    To copy/paste the settings to other clips right-click the clip in the project window that has the settings you want to apply and go to interpret footage > main > remember interpolation (shortcut: ctrl + alt + c). Then select the clips you want to apply the settings to and right-click and go to interpret footage > main > apply interpolation (shortcut: ctrl + alt + v).
    Erik Waluska
    EAWmedia
  • Marko Ristić
    June 29, 2014 at 10:00 pm
    Thanks!! That solved the problem! 🙂
