Activity Forums Adobe After Effects Expressions Automatic Font size script?
  • Automatic Font size script?
    Posted by Janmaarten De wit on March 30, 2009 at 7:46 pm
    Hi people, sorry for my shitty english. ;-P
    I’ve been searching the web like a mad man for a certain scrip.
    Is there a scrip witch automatically resizes the fonts according to the size of a composition?
    So the text always fills the maximum amount of space in my composition??
    The reason why??
    I’m using automator in combination with a script to adjust the text outside of AE, and rendering my project in the background with AErender.
    Thank U very very much in advance!!!!!
    Filip Vandueren replied 17 years, 5 months ago 2 Members · 1 Reply
  • Filip Vandueren
    March 30, 2009 at 11:20 pm
    With scripts it’s possible, with expressions it’s not.
    A script can know the pixel dimensions of a textLayer like this;
    // l=yourlayer
    rect=l.sourceRectAtTime(l.time,false);
    this returns an object with object with four attributes: [top, left, width, height].
    so rect.width and rect.height will give you pixel dimensions you can use to calculate the scla you should set your text layer to, to obtain 90% of comp.width (I assume you want to stay within safety)
    Does this set you in the right direction, or do you need a kant-en-klaar script 😉
