Activity › Forums › VEGAS Pro › Automatic Fade for Audio (Vegas6)
  • Automatic Fade for Audio (Vegas6)
    Posted by Michael Morone on January 3, 2006 at 11:49 pm
    When I put audio into the timeline, or paste audio into the timeline, there is always an automatic fade at the beginning and end of each audio event. I thought that this might be an automatic thing that can be turned off. Sure enough, under the Preferences menu (Under Edititing) I found an option that says: “Quick Fade length for audio events (ms)”; it was set at 10ms. I tried to change it to 0, but it wouldn’t let me. The lowest number I could put was 1. This seems odd to me, because in the Vegas Help it says:
    “A rapid fade is applied to the edges of audio events to soften potentially harsh transitions that can result from cutting data or splitting events. When you use a 0 ms fade, edges of new events are not faded (existing fades are not removed).
    Enter a value in the box to change the length of the fade.
    From the Options menu, choose Quickfade Audio Edits to turn quick fades on or off.”
    I even turned off the “Quickfade Audio Edits” but they still will not go away at the edges of the audio events, and I still cannot set the number to 0ms.
    Any help would be greatley appreciated.
    Michael M.
    Edward Troxel replied 20 years, 9 months ago 2 Members · 1 Reply
  • Edward Troxel
    January 4, 2006 at 3:05 am
    Turn off: Options – Quickfade Audio Events
    Edward Troxel
    JETDV Scripts
