Activity Forums Adobe After Effects Automatic Duck crashes (MC6 to AE5.5)
  • Automatic Duck crashes (MC6 to AE5.5)
    Posted by Eric Mc guire on March 15, 2012 at 3:47 pm
    I am having problems importing my AAF from Avid Media Composer 6 into After effects 5.5. I have the latest version of Automatic Duck but it keeps crashing After Effects whenever I import my AAF.
    I play with all the settings in MC6 and AE, but as far as I can go automatic duck loads at best empty files. Does it work with the new DNxHD 444 350 X MXF from AVID?
    Any other idea?
    Cheers Im in win 7 64 bit
    Eric Mc guire replied 14 years, 6 months ago 62,494 Members · 2 Replies
  • Eric Mc guire
    March 15, 2012 at 4:39 pm
    Several seconds passed before you reply Dave. Hahaha.. I have found that automatic Duck does not work with the “DNxHD 444 350 X MXF” nor the “1:1 10b RGB MXF” formats that you can mixdown in AVID.
    But you can buy this compatibility I think
    https://www.calibratedsoftware.com/store/WindowsIndividualStore.asp
    I don’t understand why I can’t mixdown in DNXHD 175x in MC6 as I did in MC5.5, not sur if I am missing some codecs or if they removed this option from MC6. It would allow me to send my files in AE5.5
    Thanks a lot Dave for the quick awnser, I always appreciate your infos on this forum.
    Eric
  • Eric Mc guire
    March 15, 2012 at 7:30 pm
    Ahh.. I was working in the “wrong” Colorspace.
    RGB 709 space allows you to render/transcode/mixdown in RGB formats:
    – DNxHD 444 350 x
    – 1:1 10b RGB MXF
    YCbCr 709 allows you to render/transcode/mixdown in video formats (rec 709):
    – AVC Intra
    – DNxHD
    – XDCAM, VC1, 1:1 10b MXF
    I usually work in RGB space in MC6.
    Working in YCbCr 709 is needed to import your AAF in After Effects with Automatic Duck!
    That being said, it might be a different story on a mac.
    Cheers
