Activity Forums Adobe After Effects Automatic Duck & Boris XML Import crashes AE CS5
  • Automatic Duck & Boris XML Import crashes AE CS5
    Posted by Dylan Harrelson on July 9, 2012 at 6:57 pm
    I have a 23.98 1080p comp in Final Cut Pro v7.0.3 that I am trying to export XML to import into After Effects. Trying both Automatic Duck’s free XML exporter and the normal XML export process. Each time I try to import the XML into After Effects it crashes After Effects. Both with Automatic Duck and with Boris TransferAE. Other XML imports with work fine except this sequence. I have deleted preferences files and rebuilt the sequence in FCP and saved again but I still continue to have the problem. Any thoughts as to what I’m doing wrong? Thanks!
    Dylan Harrelson replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
