Activity › Forums › Boris FX › Automatic Duck
  • Automatic Duck
    Posted by Peter Tours on May 19, 2009 at 1:23 am
    Has anyone ever done this successuflly? If so, can you describe your experience?
    from Boris Red 4 online manual:
    Automatic Duck Composition Import
    Red supports Automatic Duck composition import. This allows you to import your timeline from an After Effects, Avid or Final Cut Pro host system into the Red Engine. Automatic Duck’s Automatic Composition Import plugin lets you import an Avid® OMF® Composition, including all your media and clips. Supported effects are translated and recreated, and your timeline is recreated as a composition in Boris Red. In addition, your media and composition are added to the Project window.
    The following features are supported for Automatic Duck import.
    Importing OMF® Compositions from both Macintosh and Windows hosts.
    Video and audio tracks
    Submaster effects
    Color tracks
    Project size and Project FPS
    Track names
    Composite modes
    Position and Opacity
    Still Image Files
    Motion effects
    Dissolves
    Picture in Pictures (scales to 50%, an Automatic Duck limitation)
    Superimpose effects (Opacity to 50%–an Automatic Duck limitation)
    Flip, Flop and Flip Flop effects
    For more information on Automatic Duck, see your Automatic Duck documentation or visit https://www.automaticduck.com.
    FYI – I INQUIRED OF AUTOMATIC DUCK AND RECIEVED THIS RESPSONSE TODAY –
    On 5/18/09 4:11 AM, “peter tours” wrote:
    > I have read in the Boris Red 4.3 manual that I can open my entire FCP 6
    > timeline sequence – or a part of it? – in Red4.3 using you product. Which
    > product would I use?
    > Is it possible to then roundtrip the sequence back to FCP6?
    > I use Boris Red in FCP extensively so this is very interesting to me.
    We used to make a plug-in that worked inside of RED, but we stopped doing
    that a couple of years ago.
    Wes Plate
    Automatic Duck, Inc.
    Peter Tours replied 17 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
