Activity Forums VEGAS Pro automatic crossframes
  • automatic crossframes
    Posted by Gary & yvonne on October 2, 2006 at 12:06 am
    Everytime I do a cut on a clip with the S….it creats a crossfade in the audio only. I saw that somehow auto crossfades was on so i turned it off but it still doing it…..Is this the right place to turn autocross fades on the audio off?
    also….Am I suppose to leave Quantize to frames on or off?
    Thank you very much………..Gary
    Erick Tattasca replied 18 years, 1 month ago 4 Members · 3 Replies
  • Edward Troxel
    October 2, 2006 at 1:59 am
    Leave Auto Crossfades turned on. Go to Options – Quickfade Audio Events and turn it OFF.
    Edward Troxel
    JETDV Scripts
  • Doug Graham
    October 11, 2006 at 7:31 pm
    Leave Quantize to Frames “ON” for most video work.
    If you need to do an audio edit within a frame, then you can turn it off to get finer resolution.
    Regards,
    Doug Graham
  • Erick Tattasca
    August 1, 2008 at 6:16 pm
    Doug,
    I accidentally hit quantize to frame
    now all video i paste into the trimmer plays at a really slow rate, and audio.
    how do i undo this, or
    how do i find what the actual problem in settings might be
    thanks in advance for your help,
    erick
