Activity Forums Adobe Premiere Pro Automatic audio levels
  • Automatic audio levels
    Posted by John Stock on October 23, 2009 at 4:59 am
    Is there a way to automatically set the volume levels of a track, without having to painfully do it manually?, possibly with attack/release settings?
    Or is there a plug-in to do this.
    Thanks.
    Mike Velte replied 16 years, 11 months ago 2 Members · 1 Reply
  • Mike Velte
    October 23, 2009 at 6:19 pm
    You can nest a sequence into another sequence giving you a single volume rubber band.
    The Audio Mixer can also do this, but beware; the volume adjustment is part of the track and all clips in that track will be adjusted.
    You also can lasso all the clips in a track, right click on that selection and choose Audio Gain to adjust all clips up or down or normalize all peaks.
