Activity › Forums › Apple Final Cut Pro › Automatic Audio Crossfade
  • Automatic Audio Crossfade
    Posted by Tony Wilson on August 29, 2018 at 4:33 pm
    https://youtu.be/7iTVHFucpVo
    My AppleScript App mimics keypresses in order to do an instant audio crossfade.
    In FCPX Command editor:
    Toggle Audio Fade In is SHIFT 9
    Toggle Audio Fade Out is SHIFT 0
    AppleScript:
    try
    do shell script "pgrep -x 'Final Cut Pro'"
    on error
    --FCP not open so quit
    error number -128
    end try
    tell application "Final Cut Pro" to activate
    tell application "System Events"
    keystroke "[" using shift down
    key code 47 using shift down
    key code 126 --up
    keystroke "]" using shift down
    keystroke "," using shift down
    key code 126 using command down --up
    keystroke "0" using shift down
    keystroke "s" using control down
    key code 125 using command down --down
    keystroke "9" using shift down
    keystroke "a" using {command down, shift down}
    end tell
    The idea of a keyboard macro is not new, but this may be helpful.
    Tony Wilson
    12677_crossfade.app.zip
    Tony Wilson replied 8 years ago 2 Members · 2 Replies
  • Chad Greene
    August 29, 2018 at 7:18 pm
    Apple script is pretty cool. But just in case you are interested, check out this article on how to create an Audio Only transition using Motion. https://www.provideocoalition.com/audio-only-cross-fades-in-final-cut-pro-x/
    Chad Greene : Mahoney Media : Minneapolis, Minnesota : 2×2.66 GHz 6-Core Intel Xeon, 12GB Ram, OS 10.11 FCPX, Kona-LHi
  • Tony Wilson
    August 29, 2018 at 9:07 pm
    Hi Chad
    I find the compound clips to be a pain to unpick with that method.
    Tony
