Activity Forums Adobe After Effects Expressions Automated source text animation based on split
  • Automated source text animation based on split
    Posted by Samik Pal on April 7, 2021 at 7:18 pm
    Hello experts,
    I have newly started in AE and I came across source text animation.
    I have a requirement where I want to show multiple text on source text keyframe animation. I was wondering instead of writing each text on the keyframe is there a way to automate this.
    For example, I have created two text layers and the empty layer is referring to the data source (text source) and I know how to split them based on a delimiter. Please refer to the screenshot.
    Now, Is there a way for me to tell AE to increase the value dynamically inside word[] in line 3 by +1.
    If possible, I desire the code to return word[0] at 0000; word[1] at 0001 and word[2] at 0002.
    Many thanks in advance.
    Yoan Boisjoli replied 5 years, 5 months ago 2 Members · 8 Replies
  • 8 Replies
  • Yoan Boisjoli
    April 7, 2021 at 7:44 pm
    Hi Samik !
    I think you could just have the time rounded to floor in there (if you want a new word every second).
    n = Math.floor(time);
    And just put the “n” variable inside the square brackets.
    Let me know if that makes sense !
  • Samik Pal
    April 7, 2021 at 7:56 pm
    Hello Yoan,
    Thanks for looking into this and I have tried what you suggested but it does not return what I had in my mind. At 0001 I was expecting the code return test2. I expect to see a new word every frame.
    Many thanks again
    t=thisComp.layer("test1-test2-test3").text.sourceText;
    word=t.split("-");
    word[n]
  • Yoan Boisjoli
    April 7, 2021 at 8:02 pm
    Hey Samik! Are you referring to frames or seconds?
  • Yoan Boisjoli
    April 7, 2021 at 8:03 pm
    if you’re referring to frames, try this:
    n = Math.floor(timeToFrames());
  • Samik Pal
    frames
  • Samik Pal
    April 7, 2021 at 8:05 pm
    found it
    word=t.split("-");
    n = time/thisComp.frameDuration
    word[n]
  • Samik Pal
    April 7, 2021 at 8:13 pm
    Tried with both and both works. mAny thanks for your time Yoan
    t=thisComp.layer("X1-X2-X3-X4").text.sourceText;
    word=t.split("-");
    //n = time/thisComp.frameDuration
    word[n]
  • Yoan Boisjoli
    April 7, 2021 at 11:17 pm
    Glad you found by yourself also! And glad I got to help! Have a good day!
