Activity Forums Adobe Premiere Pro Automated Premier Pro Sequences
  • Automated Premier Pro Sequences
    Posted by Adam Goldstone on February 5, 2014 at 12:05 pm
    Hey Guys,
    This is my first post on here so bare with me 🙂
    I currently use After effects to key out my green screen. Once rendered from there I import it to Sony Vegas. I use Sony Vegas because it allows me to add thousands of render regions easily and with the help of the Excalibur plug-in, render each region out with its corresponding file name.
    To clarify I render each file i.e. A_names.mov, B_Names.mov etc from After Effects and import these into Sony Vegas. At which point I can add render regions for Adam, Aaron, Abi etc and render those names out of Sony Vegas i.e. Adam.mov, Arron.mov etc.
    I want to try and get my work flow all under the Adobe CC Software umbrella to take advantage of the dynamic link features and cut render times and generally improve my workflow.
    I have two questions:
    1) We have a project coming up where I need to render out 8000 separate names. Does this sound manageable in Premier Pro?
    2) Is there anyway with ExtendScript (which doesn’t currently seem to support Premier Pro very well) or a plug-in to allow me to make sequences in Premier Pro from a .csv list (of names), I was thinking each sequence could be 3 seconds as a name file would never be over that. I can then go through one by one and insert into its corresponding sequence the correct name from the footage. Then in and ideal world, it would be great to have another script that trims the excess off each sequence after.
    Does anyone think this is achievable or am I better staying with my current work flow?
    Thanks so much for any time or thought given to my problem 🙂
    Kind regards
    Adam
    Abhi Nash replied 12 years, 6 months ago 2 Members · 1 Reply
  • Abhi Nash
    February 7, 2014 at 4:20 pm
    I have never tried this before,Like you,I render or directly import my After Effects Composition into Premiere to edit.
    I have never tried using ExtendScript or anything of that sort.
    I always name my files like Scene_ID_Time_Format_AndExportSoftware so this helps me manage all my Renders and Compositions to have a better workflow.
    And,If you have never tried using ExtendScript,don’t waste any time on it.Work with the current workflow.
    And learn ExtendScript if it’s capable of doing this.
    Cheerio,
    Abhi
