Activity Forums Adobe After Effects Automated Lip Sync
  • Automated Lip Sync
    Posted by Cody Kyle on April 7, 2010 at 8:34 pm
    I was wondering that for AfterEffects is their an effect that lip syncs a .wav audio file to an still image on the screen and manipulates the images lips on the the screen with it or is their an outside program that does this when you import it into AfterEffects. I am currently am working with AfterEffects CS3 and (I may be mistaken) a previous employee was able to do this some way. Now I am not talking about the lips syncing up exactly with the audio, more like a jibber jabber kind of lip moving with the audio. Has any one heard of anything similar to what I am saying? Any feedback would be appreciated.
    Sincerely,
    Perplexed
    Rob Mclendon replied 13 years, 11 months ago 7 Members · 6 Replies
  • Todd Kopriva
    April 7, 2010 at 10:25 pm
    You got an answer to this on another forum. It is good etiquette to cross-post the answer when you cross-post a question.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Tudor “ted” jelescu
    April 8, 2010 at 8:46 am
    Straight from the cow’s mouth… actually from Aharon Rabinowitz https://library.creativecow.net/articles/rabinowitz_aharon/lip_synch.php
  • Richard Shaw
    May 25, 2010 at 12:12 pm
    This is probably way too late to help you out, but will hopefully be of use to someone else.
    Obviously perfect lip sync can’t be magically done for you, but it doesn’t sound like that’s what you’re after.
    I think you mean something along these lines:
    https://www.youtube.com/watch?v=adc3MSS5Ydc
    This can be done by converting the audio to keyframes (right click, keyframe assistant). This creates a new null (Audio Amplitude). Parent the mouth layer’s position to both channels and alter the expression slightly to something like this:
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    value+[0, temp]/2
    Adding “value” uses the layer’s original position. Use “+” or “-” to push the mouth down or up (down makes sense here, but up could be used to raise the eyebrows in time with the mouth, for example).
    Changing the first “temp” to 0 prevents x axis (sideways) movement.
    Dividing or multiply by the required amount will limit how far the mouth layer moves (here I’ve arbitrarily divided by 2 just as an example).
    In a profile view of the character, the mouth layer’s rotation could be parented to the Audio Amplitude instead of position.
    If the mouth is moving a bit too erratically, use the smoother (window, the smoother) on the Audio Amplitude layer. Click on “Slider” to select all keyframes, Choose a tolerance level (probably 2-4 or so) and hit apply. There will no-longer be a key on each frame and all keys will now be easy ease.
    Hope this is helpful.
  • Byron Purvis
    August 16, 2010 at 8:58 am
    “Dream on”? Your comment is not at all helpful. You should just refrain from commenting unless you have something useful to say. It’s a very valid question, and something I’ve been researching for quite a while…
    There are a number of lip sync applications that can take an audio file, analyze the phonemes and help automate the process. Papagayo and the Lipsync widget for Mac do a fair job of syncing and making after effects keyframes, but it takes some fidgeting and expressions to get it to work! There’s also a java app called JLipSync, but I didn’t have much luck with it since it would only take 8-bit mono wav files as input.
    As far as I know, there is no completely automated solution for after effects yet, but I’m sure it’s only a matter of time/money.
    If you want to step away from After Effects, applications like Anime Studio Pro 7 or ToonBoom Studio might be better solutions, but they cost between $200-400.
    The current solution I’m using is not completely automatic, but it does speed up the process significantly…
    I use a combination of Aaron Rabinowitz’s tutorial and a technique I found on youtube, where I speed up the mouth selection by pick-whipping the +/- keys (which normally control rotation) on a null layer, to a time remapped pre-comp containing my mouth shapes.
    See the following links for more info …
    https://www.youtube.com/watch?v=c5GIOtfYWpQ
  • Eddio Pina
    June 5, 2011 at 4:32 pm
    NO… Don´t Dream on…
    Wake up insted…
    Ae is able to do automated audio animations. And YES without plugins.
    Firts. You must understand about Lip Sync. Our friend Aharon Rabinowitz did an excelent job explaining this in this post.
    Once you know how to lip Sync yo are ready to work with automated lip syncing.
    You must convert your audio file to Keyframes. to do this. select your audio layer in the AE timeline, then go to Animation Menu > Keyframe Assistant > Convert Audio to Keyframes.
    You´ll get a new layer in your timelime, this is a keyframe representation of your audio file. It has 3 layers, you can delete 2 of them (if you want to) and work with only one layer
    Click on the “Slider” option of the keyframe layer to select it and them in the Graphic Editor (over the timeline) to see what you got.
    Remember you must have done a time-remap of your animation the way Aharon shown above.
    Now you can start asigning values to your Animation. You can “link” your keyframe layer to the Lips layer and watch if it works
    Parhaps you must perform some adjustements, but this is it
    Not so hard…
    Best reggards…
  • Rob Mclendon
    October 18, 2012 at 10:41 am
    This response has been EXTREMELY helpful. Thank you, thank you, thank you!!!
