Activity Forums VEGAS Pro Automated deletion of individual frames
  • Automated deletion of individual frames
    Posted by Greg De villiers on April 19, 2011 at 9:09 pm
    Hey, is there any way to automate the process of removing individual frames in Vegas Pro 10?
    For example if I have a clip and want to remove 2 out of every 3 frames?
    Danny Hays replied 15 years, 4 months ago 3 Members · 4 Replies
  • Danny Hays
    April 20, 2011 at 12:04 am
    You can render avi at ten frames per second,captured at 30p or 29.97. It would look the same as removing 2 of three frames.
  • John Rofrano
    April 20, 2011 at 2:45 am
    You could use a script to do this like the Image Sequence tool in VASST Ultimate S Pro plug-in. It will render and image sequence at any interval you want. You could then import this as an image sequence and it will behave as a single piece of media. I believe the Excalibur plug-in has something similar.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Greg De villiers
    April 20, 2011 at 12:34 pm
    Thanks to you both.
    Danny, I’m still new to this, say I have a .mov file, how would I go about rendering at 10fps and then inserting this new file into my project timeline?
  • Danny Hays
    April 20, 2011 at 3:27 pm
    In your render as window, type 10 in the fps area. I probably says 29.97 and can be dropped down to choose but 10 isnt one of the options, so type it in there.
