Activity Forums Adobe After Effects Expressions Automated Closed Caption Tweak?
  • Automated Closed Caption Tweak?
    Posted by Darryl Torke on February 20, 2015 at 12:19 am
    Hi, i’m using the code on this tutorial (pasted below). What it does is use the comments on the layer to display 5 words at a time for closed captions. This is great, however I have a monologue I’m trying to CC and there are many pauses – moments where the speaker is trying to take time – in her speech. The result of the expression below forces 5 words no matter what. So if the speaker says “Wait. (10 second pause) I’ve got something to say.” The CC will say “Wait. I’ve got something to” – “say”. Ideally, I’d like “Wait” to be on it’s own line and actually wait for the next line before showing up. Even if I have to do something manually I don’t mind, but currently it’s a real pain tricking it into breaking up pauses. Can anyone think of a tweak to this expression so I could modify it slightly?
    L = thisComp.layer("text");
    max = 5; // number of words to display
    n = 0
    if (L.marker.numKeys > 0){
    n = L.marker.nearestKey(time).index;
    if (L.marker.key(n).time > time){
    n--;
    s = " ";
    if (n > 0){
    base = Math.floor((n-1)/max)*max + 1;
    for (i = base; i < base + max; i++){
    if (i <= L.marker.numKeys){
    s += L.marker.key(i).comment + " ";
    s
    Dan Ebberts
    replied 11 years, 7 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    February 20, 2015 at 2:44 am
    That expression was just intended as a quick and simple demonstration for importing metadata from the speech transcription function of Premiere. I suppose you could create a script that would search for delays over a certain duration and create some extra markers with blank comments (or you could add them manually).
    Dan
