Activity Forums Adobe Premiere Pro Automate to sequence
  • Automate to sequence
    Posted by Philippe Verdoni on June 26, 2006 at 1:07 pm
    I am trying to make a 720 x 576 pixels movie with a series of 3072 x 2304 pixels pictures using the Automate to sequence command. The resulting sequence only takes a quarter of the pictures and does not resize them. The same operation using 2048 x 1536 px pictures had worked pretty fine. There is probably a parameter that I have not properly set but I dont know which one. I would appreciate your help in this matter.
    Aanarav Sareen replied 20 years, 3 months ago 2 Members · 1 Reply
  • Aanarav Sareen
    June 26, 2006 at 4:24 pm
    I am not in front of my editing system at the moment, but if you go to Edit > Preferences > General or look for Project Settings, there will be a check box that indicates ‘scale video to frame size’ select that box and re-import your images.
    Aanarav Sareen
    premiere@asvideoproductions.com
