Activity Forums Adobe Premiere Pro Automate to sequence trouble
  • Automate to sequence trouble
    Posted by Michael O’brien on May 18, 2008 at 7:58 pm
    Hi, I’m having trouble with Automate to sequence. In the placement drop down menu I only have “sequentially” when there should be “at unnumbered markers” as well.
    I’m tring to add still images to music and understand that I should be able to set markers where i want and then automate to sequence at unnumbered markers to place the images where i desire.
    Any ideas/solutions very appreciated.
    Mike Flanagan replied 17 years, 1 month ago 3 Members · 2 Replies
  • Martin Rose
    May 21, 2008 at 3:52 am
    Same problem here
    If you find out if this is fixable let us know
    Thanks Martin
  • Mike Flanagan
    August 17, 2009 at 8:07 pm
    Mr. O’Brian … I have exactly the same problem the Automate to Sequance does not display the chouice of using unnumbered markiers in Premiere Pro CS3 … Have you ever been able to get an answer why?
    Mike Flanagan
    Cell 936-827-5401
