Activity › Forums › Adobe Premiere Pro › Automate to sequence not working with subclips
  • Automate to sequence not working with subclips
    Posted by Gabriel Sanchez on February 14, 2023 at 1:31 pm
    i made a Scene detection in a 4 min long clip to extract subclips for each take it has. Then i want to Automate to sequence all this subclips in a timeline where i previously put markers following the rithm of the music, choosing the Put in sequence markers option. It put them there, but the content of each subclip doesn´t correspond to the subclip made. So i end with lots of cuts placed right in the sequence markers but the clips show always the same extract of the master clip repeated. It is as it hasn´t respected the in and out points in each subclip. If i add them manually to the sequence, then they show the right cut, but can´t get the Automate to sequence in markers to work.
    Is it there any other workaround im missing or it is just a bug? I have PPro v. 23.1.0 in Windows 10
    Gabriel Sanchez replied 3 years, 7 months ago 1 Member · 1 Reply
  • Gabriel Sanchez
    February 14, 2023 at 3:02 pm
    Note: creating subclips manually DOES work, so i suspect its an issue with the Create subclips from cuts option in the new Scene Detection feature. Sublips created by the Scene Detection option also are right if you drag them to the origin monitor or to the timeline, noticed than even metadata in this subclips is right too, it shows in and out points, it´s only the Automate to sequence option which doesn´t add the right cuts of every subclip to the timeline.
