Activity Forums Adobe Premiere Pro Automate to Sequence crashes Premiere Pro 2.0
  • Automate to Sequence crashes Premiere Pro 2.0
    Posted by Wtdear on July 24, 2006 at 11:46 pm
    If I select more than about 3 clips from the bin, highlight them, and select ‘automate to sequence’, I get an error message that says ‘PPro has encounted an error and must shut down program. I’ve never had this problem before with this feature. I’ve selected up to 80 clips before and have them all move to the timeline with the transitions in place………what gives???
    Tod
    Jerry S replied 20 years, 1 month ago 3 Members · 2 Replies
  • Dave Friend
    July 25, 2006 at 5:43 pm
    The one time I had this behavior it was due to a corrupt clip. Never did figure out in what way the clip was corrupt. I could scan thru it OK, but about midway through playback things would lock up. Re-capturing the bad boy fixed the problem.
    Dave
  • Jerry S
    July 26, 2006 at 4:03 am
    This is a problem yet defined and acknowledged in PPRO2.0. If you realy want to see it get ugly rename a clip already on sequence. Just right click on clip rename it and watch the fun. Until you do some clip and past will it get fun but the end result will be PPRO will crash. Talked to friend at ADOBE and they are confused. I suspect the rename and edit cut and clip realy confuses PPRO and eventually some windows crash occures.
    Jerry
