Activity Forums Adobe Premiere Pro Automate to Sequence Clip Length
  • Automate to Sequence Clip Length
    Posted by Andrew Bergner on October 4, 2012 at 3:23 pm
    Hello all! Using the Automate to Sequence feature, is there a way to specify that each image in a sequence fill to the next marker?
    I work a lot with imported PowerPoint presentations and when I use Automate to Sequence it inserts the slide images just fine, but they are all the same length. I’d love to basically “Fit to Fill” for the duration between each marker since the durations vary.
    I’m grateful for any advice, as always! Thanks.
    Gabriel Sanchez replied 13 years, 11 months ago 2 Members · 2 Replies
  • Andrew Bergner
    October 4, 2012 at 3:24 pm
    Edit: I’m working in CS6
  • Gabriel Sanchez
    October 4, 2012 at 11:31 pm
    First set the still images duration as long as your longest interval between markers, do it in the general tab of preferences before importing your media to the proyect, as changing this option doesn´t change duration of media already imported.
    Then select “put in markers” option in the automate to sequence window.
    Regards
