Activity Forums Adobe After Effects Expressions Automate script to split 1 Long comp into multiple smaller renders.
  • Automate script to split 1 Long comp into multiple smaller renders.
    Posted by Craig Trayler on September 9, 2022 at 8:53 pm
    Hi, I have searched about but have not found what I need.
    In After Effects I do documentary projects that are over an hour long, and always fear for an error or power cut with a 10 hour render time export.
    I would like to know if there is a script that you can input a splitting number and then the script will split up the full render into small chunks?
    For example if I have a project that is 60 Minutes long, and I want it to be split into 6 sections, then the script will split the project into 6 parts of 10 minutes or 60 parts of 1 minute and just name the output with an underscore and a number going from 1 upwards depending on how many splits there are going to be, and I just hit render and leave it to do it’s thing.
    And after that I would just mux them all together.
    Thank in advance for any help.
    Craig Trayler replied 3 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
