Activity › Forums › Adobe Premiere Pro › Automate ‘scale clip to sequence settings’
Posted by Ann Foo on June 6, 2025 at 1:47 amI think there used to be a setting in Premiere so that if you put a clip in your sequence, it would automatically scale the clip to fit full frame in the sequence (if your clip and sequence had mismatching resolutions).
Am I imaging this? Does anyone know where that setting is, if it exists?
Ann Foo replied 1 year, 3 months ago 3 Members · 4 Replies -
Mads Nybo jørgensen
June 6, 2025 at 6:59 amHey Ann,
Interestingly, just a few weeks ago, I came across that setting in Premiere Pro preferences or Sequence settings – can’t remember which, as Premiere Pro was crashing all over the place on the project I was trying to get out of the door.
It is in there, but I do remember thinking “Why would I ever want to do that”?
Which is obvious if you have a large amount of photo/graphics files that you need to scale.If not in preference, check your sequence settings.
Hope that this helps.
Mads -
Devrim Akteke
June 6, 2025 at 8:32 am -
Ann Foo
June 6, 2025 at 1:24 pmBrilliant, thanks so much!!!
For anyone following, this is for PC users. For Mac users, this setting is under the Premiere Pro menu, Settings > Media, and choose the option ‘Fit to Frame’.
Ann Foo
June 6, 2025 at 1:32 pmIt doesn’t just scale pictures and GFX, It scales video too. I find it very useful because we are increasingly living in a world of mixed mediums…. multicam shoots often use different cameras. Iphone footage is often incorporated for an experimental look.
Typically on a feature, the DIT should standaradise all the proxies to 1080 for me, but that’s not hapening on my current gig and I don’t understand why. Some stuff is coming in at 4k, some 1080, some a weird format which requires it to be scaled up 115%. Needless to say it’s doing my head in but this automatic scale function is a great way to get around the problem
