Activity Forums Adobe After Effects Expressions Automate Numbers
  • Posted by Shashank Raghu on November 20, 2020 at 5:31 pm
    Hello,
    I’m trying to automate the number where if I disable one number layer another number has to continue from the previous one.
    for example – there are 10 text layers which contain 1 to 10 in order, if I disable the 5th layer(which is “5”) the 6th layer has to change to “5” and the 7th layer has to change to “6” and so on.
    I tried
    n = [];
    if(thisComp.layer(index+1).enabled = true){
    parseInt(thisComp.layer(index + 1).text.sourceText) + 1;
    } else {
    for (i = index; i < (thisComp.numLayers); i++){
    break;
    n[i] = parseInt(thisComp.layer(i+1).text.sourceText) + 1;
    but it is not working when I disable the layer.
    Shashank Raghu replied 5 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 20, 2020 at 6:34 pm
    Something like this should work:
    n = 10; // number of layers participating
    count = 0;
    for (i = 1; i <= Math.min(thisComp.numLayers,n); i++){
    if (thisComp.layer(i).enabled) count++;
    if (i >= index) break;
    count
  • Shashank Raghu
    November 20, 2020 at 6:57 pm
    Yeah, it is working, thanks a lot.
