Activity Forums Adobe After Effects Automate Layer placement in new compositions
  • Automate Layer placement in new compositions
    Posted by Dennis Colon on January 7, 2020 at 5:08 pm
    I have a watermark thats made out of a text layer and a .png layer at half opacity that I need to appear in every new composition I make for a mobile application I created.
    The text layer needs to be presented as a text layer and the .png separate as well. I cant have them in my composition as a pre-comp, or as a transparent video, im looking for a way to automatically run an expression or script that would ingest them into new compositions automatically
    Drew Hutchison replied 6 years, 7 months ago 2 Members · 1 Reply
  • Drew Hutchison
    January 7, 2020 at 6:59 pm
    If each composition is going to be the same size then a working smarter not harder solution would be to just save a “template” comp and duplicate it each time you need to create a new comp with that watermark.
    If you need to edit a master file in a comp that’s being duplicated and don’t want it being affected in your other comps in the project, I would recommend using True Comp Duplicator script.
    This will create a duplicate of everything designated in your selected comp even subcomps and everything inside them so you can edit and adjust anything without messing up your other comps.
    Here is a link to True Comp Duplicator. I am not affiliated with them, just a fan of the script!
    https://aescripts.com/true-comp-duplicator/
