Activity Forums Apple Final Cut Pro Legacy Automate Clips to Timeline FCP
  • Automate Clips to Timeline FCP
    Posted by Jared Isham on May 9, 2011 at 10:44 pm
    I am attempting to set up an automation where my clips in my bin can be laid down on my timeline matching the timecode. I was attempting to use Automator to record me opening a file in the viewer, copying the starting timecode, pasting the starting timecode to the timeline and inserting the footage at that timecode point.
    I was able to successfully set up an automation except it only applied to the clip I recorded the action with. What I want to do is to be able to select the files in the bin and run the automator.
    If it is not possible to do with automator is there a way that I can write a script that will run in FCP to achieve the same effect?
    Jared
    Jared Isham
    Stage Ham
    https://www.stgham.com
    film. video. web media
    Jeremy Garchow replied 15 years, 3 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    May 10, 2011 at 2:08 am
  • Jared Isham
    May 10, 2011 at 6:53 pm
    Awesome Thanks. Now that I am working with sequenceLiner I am trying to get a few things to work based off of the manual. Here is what I am trying to achieve:
    4 Cameras:
    A CAM
    B CAM
    G CAM
    H CAM
    Audio:
    8 channel audio recording
    I separate the clips into their respective bins and create a target sequence.
    I would like to make it so that I can have A CAM on video track 1, B CAM on video track 2, G CAM on video track 3, H CAM on video track 4 and audio below everything else. The clips overlap/have the same timecode which will be multiclipped once everything is in sync.
    Do you know if this is possible with sequenceLiner or do I have to do each track individually? If so, what is the recommend bin set up so that it works properly.
    I couldn’t find a forum on their website so I figured this was the best place to seek help.
    Jared Isham
    Stage Ham
  • Jeremy Garchow
    May 10, 2011 at 7:06 pm
    I would email the architect of the application, Andreas. He will help you.
    Jeremy
