Activity Forums Adobe Photoshop Automate Aspect Ratio change
  • Automate Aspect Ratio change
    Posted by Libby Austin on February 9, 2009 at 5:23 pm
    Hello,
    I want to automate Photoshop CS3 to change the ratio of a series of stills from 720×540 (they were converted from PPT) to 720×480. I plugged in 720×480 to the Image Processor, but I’m getting 641×480.
    I see that I can’t use Image Processor to change the aspect ratio, so I looked at Batch processes and didn’t see a tool for what I want to do. Am I missing something? I am able to change the file sizes individually, manually, but I have 180 files!
    I realize that what I want to do will stretch the images horizontally, but that’s OK!
    Any thoughts?
    Elizabeth
    David Johnson replied 17 years, 6 months ago 2 Members · 1 Reply
  • David Johnson
    February 10, 2009 at 11:25 pm
    I frequently do a similar batch process (720×486 rectangular pix to 720×540 square pix) in order to send clients screenshots for them to approve without them asking “why does that circle look like an egg?”.
    Just record an Action as you make the changes to one of the images, then use batch process to do the rest. Go get a frosty beverage and, when you come back, your work is done. ;~)
    Note that, if you’re going from square pix to rectangular pix, you’ll not only need to change the image size, but also the aspect ratio (and don’t be tricked by Photoshop’s annoying “aspect ratio correction”, which only affects what you see in Photoshop, not the actual image). It’s hard to say exactly what is best to do without seeing the images in question, but you might consider cropping instead of stretching, if the content of the images will allow that.
