Activity Forums Adobe Photoshop automate action on movie file
  • automate action on movie file
    Posted by Mariusz Cichon on December 2, 2009 at 7:21 pm
    I have a QT video file with an alpha channel and I did some fine cleaning of the video image in Photoshop using the Eraser tool.
    I would like to find out necessary steps to automate erasing the same part of the frame on all frames of that Quick Time file. It is 15seconds @ 30fps. It would be very helpful, thanks.
    I have done it on folder of images but not worked with video QT file.
    Thank you,
    Paul Benson replied 16 years, 8 months ago 3 Members · 2 Replies
  • Richard Harrington
    December 5, 2009 at 2:55 pm
    Rotoscoping cannot be automated
    You can try keying in After Effects… but not erasing frame by frame
    You can also look at masking in AE
    Richard M. Harrington, PMP
    Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Paul Benson
    December 27, 2009 at 5:56 am
    If it is the exact same spot in each frame, then I think you can create an action. Did you try? Use the select tool and then delete the selection. I tried something like this once while playing around and achieved something like this. Not sure how ‘tricky’ you can get (like using the same path as a selection, or something like that).
    Pauley
