Activity Forums Adobe After Effects Expressions Automate 4-color gradient?
  • Automate 4-color gradient?
    Posted by Peter Janoschka on April 28, 2016 at 9:47 am
    Is there a way to pick the color of the 4-color gradient automatically over time?
    Do you know any script or expressions would do it?
    I have a “4-color gradient” to fill masked out parts. On the layer with 4-color gradient I pick the colors of the Footage next to the mask. That works fine with plain color or blurred areas. But as soon as the light in the shot changes , the colors get darker or brighter. So it would be nice to have a way to change the colors of the 4 corner points automatically in every frame.
    Or maybe there is a much better way?
    Thanks for your help!
    Peter Janoschka replied 10 years, 4 months ago 2 Members · 2 Replies
  • Ross Klettke
    April 28, 2016 at 3:37 pm
    On the footage layer make 4 Color Control effects (in Effects > Expression Controls > Color Control)
    Then for each Color Control, add the sampleImage expression:
    sampleImage(point, radius = [.5, .5], postEffect = true, t = time)
    — swapping in the correct value for point
    And finally, in the 4-Color Gradient effect add expressions to each color linking them to the Color Control effects
    Hope that helps!
  • Peter Janoschka
    April 28, 2016 at 6:04 pm
    Hi Ross!
    This works just perfect! Thank you so much!
    Best,
    Peter
