Activity Forums Apple Final Cut Pro Legacy Autoduck question
  • Autoduck question
    Posted by Joe Procopio on December 1, 2009 at 5:30 pm
    can I take a folder, or bin from FCP and use AD so I can import it into AVID, or do I need to take all the clips, put it into a sequence, and then duck that for AVID?
    Broadway Video, NYC
    AVID/FCP editor/engineer
    Joe Procopio replied 16 years, 9 months ago 3 Members · 3 Replies
  • Rafael Amador
    December 1, 2009 at 5:38 pm
    Hi Joe,
    Works by importing sequence.
    Import a Bin makes no much sense for me.
    Rafael
    http://www.nagavideo.com
  • Shane Ross
    December 1, 2009 at 5:44 pm
    Importing a bin DOES make sense… you have footage in an Avid that you want to now work with in FCP.
    NO, the Duck does not do bins…sequences only. So if you want to get the footage to FCP, make a sequence with the footage, then Duck that over…Then you can load the individual clips (the duck makes QT ref movies of them) by dragging the sequence to a bin.
    Shane
  • Joe Procopio
    December 1, 2009 at 5:54 pm
    must be sequence, thanks! it’s going the other way, from FCP to AVID, but same thing…AD Export
    Broadway Video, NYC
