Activity Forums Apple Final Cut Pro Legacy AutoAlign 100 source clips to matching sequence timecode
  • AutoAlign 100 source clips to matching sequence timecode
    Posted by Daniel Damato on April 14, 2006 at 3:26 pm
    The idea is to batch edit into a sequence 100 clips, by selecting them all and dragging them into the timeline. Then, based on the souce clip timecode, each clip would locate to its exact same timecode location on the sequence side.
    Clip 1 source TC 01:12:12:00 would auto locate to that same TC on the sequence side.
    Clip 2 source TC 01:12:47:12 would auto locate to that same TC on the sequence side and so on.
    David Bogie replied 20 years, 5 months ago 4 Members · 3 Replies
  • Mark Raudonis
    April 14, 2006 at 4:54 pm
    Daniel,
    This kind of task seems perfectly suited for a new third party program that works with FCP called “Traffic” by XM/edit. It uses a “node based” approach to automating multiple steps or processes. It’s worth giving it a look. https://www.xmedit.com/
    Mark
  • Arnie Schlissel
    April 14, 2006 at 7:17 pm
    You don’t even need Traffic. If you sort by timecode, & then drag them into your timeline, they’ll already be in sequence. Whether or not they ‘align’, say a clip with starting TC of 1:23:32;18 lining up to the timeline at 1:23:32;18 is another matter. That may take some additional work.
    Arnie
    https://www.arniepix.com
  • David Bogie
    April 14, 2006 at 9:56 pm
    apple.com has a feedback page for FCP.
    A tool like “distribute selected in time” (similar to a time distribution function in After Effects) would be much nicer to have than those freakin’ Autoselect thingies.
    bogiesan
