Activity Forums DaVinci Resolve Auto White Balance in Resolve Studio 16
  • Auto White Balance in Resolve Studio 16
    Posted by Peter Robertson on April 26, 2020 at 7:55 am
    Hi
    I have a clip from a client and the white balance is constantly changing. There is a large area of white wall in the background that is always visible and could be used as the reference for white.
    Is there a way to automatically keep that color locked at a white value frame by frame while applying that correction to the whole image? I know there is “Auto Color” but that only uses a single frame and does not track any color balance changes.
    Many thanks
    Peter
    Glenn Sakatch replied 6 years, 4 months ago 2 Members · 1 Reply
  • Glenn Sakatch
    April 26, 2020 at 3:32 pm
    you would have to keyframe between areas of the greatest variation with an auto color (if you want to use autocolor) and let the machine adjust the inbetweens.
    I wouldn’t try to do every frame, you will just get flickers in the color. Let the box do a gradual change between them.
    Try breaking the shot into halves with your keyframes…then halves again, and see what you end up with.
    Glenn
