Activity Forums Adobe After Effects Expressions Auto-vertically align text layer fed from essential graphics
  • Auto-vertically align text layer fed from essential graphics
    Posted by John Angless on December 2, 2019 at 12:18 am
    Hi, I’m new to this forum so apologies if this has already been covered somewhere.
    I’m building some templates in Essential Graphics to enable our operators to add animated titles to edits at speed (and scale!) in premiere.
    Essentially, I want the text to always be vertically aligned in the centre no matter haw many lines of text there are (the font is large so it’s like 6 lines max).
    It’s left aligned and I want the horizontal position to remain the same (I’m using a text box so the text will automatically wrap onto the next line).
    I’m assuming I need an expression on the position of the text layer but my knowledge of expressions is limited to “wiggle()” and “time*”!
    I looked at Evan Abrams’ description and thought maybe this technique could work but I’m struggling to figure it out.
    Any suggestions welcome!
    Cheers
    John
    y=s.sourceRectAtTime(time-s.inPoint,true).height;
    Baldur Helgason replied 2 years ago 3 Members · 3 Replies
  • Andrei Popa
    December 3, 2019 at 8:15 am
    Put this expression to your anchorpoint
    var top = sourceRectAtTime(time,false).top;
    var myHeight = sourceRectAtTime(time,false).height;
    var y = top + myHeight/2;
    [value[1],y]
    If you want the anchor point to be in the middle vertically as well as horizontally use this:
    var left = sourceRectAtTime(time,false).left;
    var myWidth = sourceRectAtTime(time,false).width;
    var x = left + myWidth/2;
    [x,y]
    Andrei
    My Envato portfolio.
  • John Angless
    December 5, 2019 at 3:37 am
    Hey Andrei,
    Just to let you know this worked perfectly for what I needed to do – many thanks!
    Cheers,
    John
    [value[1],y]
  • Baldur Helgason
    August 18, 2024 at 12:23 am
    I just signed up so I could say thank you for this incredibly helpful post!
