Activity Forums VEGAS Pro Auto Trim – Phrase Concatenator for Vegas
  • Auto Trim – Phrase Concatenator for Vegas
    Posted by Omer Aydin on October 30, 2018 at 12:31 pm
    I need to remove all audio gaps in a long speech video. It would be easy if Sound Forge’s Auto Trim tool worked in Vegas.
    I need both audio and video event to get trimmed according to the gaps in audio event
    Is there any tool / script for Vegas that chops a video event just like the `Auto Trim` / `Phase Concatenator` tool does in Sound Forge?
    Mark Barton replied 7 years, 9 months ago 3 Members · 4 Replies
  • Marco Baer
    October 30, 2018 at 5:09 pm
    Vegasaur’s “Silence Detector” would create Regions around silent audio and using Vegasaur’s “Delete Inside Region” tool would then delete that space.
  • Omer Aydin
    October 30, 2018 at 5:43 pm
    Thanks Marco,
    I’ve installed Vegasaur, I’ve found the Markers tool but can’t find the Silence Detector.
    Online manual says it’s under “Vegasaur > Audio > Silence Detector” but there is no such menu.
    I’m using Vegas 12 so I’ve installed 2.7.1.
    Are you using a newer version?
  • Marco Baer
    October 30, 2018 at 6:02 pm
    Yes, I use the latest version 3.4 of Vegasaur in Vegas Pro 16.
  • Mark Barton
    November 9, 2018 at 3:27 pm
    Looks like the Silence Detector was added in version 3 according to the release notes.
    Notable fixes/changes in Version 3.0 (2016-09-20)
    Vegasaur 3.0 requires VEGAS Pro 14 or newer. You can install this version side-by-side with the older Vegasaur versions – Vegas Pro 8-13 will continue to use Vegasaur 1.x or 2.x, while the newer versions of Vegas Pro will use the new Vegasaur.
    A bunch of technical changes: new .NET Framework, new Vegas Scripting API, updated GUI library etc.
    Silence Detector: Finds the silence in the media files.
    Still Images Panel: Indispensable tool for animators. Fast way to change “New still image length” setting and more.
    Batch Stabilization: Added support for Mercalli V4 Stabilizr plug-in
    By default, Vegasaur uses dark color skin, but you can easily change it in Preferences window
