Activity Forums Avid Media Composer Auto sync
  • Posted by D Hudson on July 1, 2010 at 6:18 pm
    Using Avid Auto sync and there is some drift.
    I have manually synced for years and there always was some
    drift between the code on the smart slate and what is on the TC track (1-5 frames). Is there a way to adjust the new subclip’s audio to get accurate sync?
    D Hudson replied 16 years, 2 months ago 2 Members · 2 Replies
  • Job Ter burg
    July 1, 2010 at 11:43 pm
    As long as you are in a 35mm project (or if you have turned on 35mm film options), you can use Perf Slip to adjust sync up to a quarter of a frame.
  • D Hudson
    July 2, 2010 at 2:13 pm
    Yeah baby!! that’s what I’m talk’n “bout!!!
    Good to learn a new trick.
    dhudson
    sr.editor PVC
