Activity Forums Maxon Cinema 4D Auto stagger selected keyframes
  • Auto stagger selected keyframes
    Posted by David Wiffen on August 21, 2009 at 12:02 pm
    Hi All,
    I used to use OffsetAnimation plugin back in the day on 9.5 but this no longer works in 10+.
    Does anyone know of an alternative to this?
    All I need to do is offset/stagger loads of keyframes in the timeline (mograph is no use in this situation).
    Many thanks guys.
    Adam Trachtenberg replied 17 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    August 21, 2009 at 5:09 pm
    [David Wiffen] “(mograph is no use in this situation).”
    Au contraire — you can use MoGraph for this. Grab all of your objects, drop them in a cloner, set the mode to iterate and make sure the fix clones box is unchecked. Set the number of clones to the number of objects.
    Now apply a step effect, uncheck the P/S/R parameters and adjust the time offset parameter to suit your needs.
