Activity Forums Adobe After Effects Auto set duration of sequence equal to selected clip.
  • Auto set duration of sequence equal to selected clip.
    Posted by Flo De haan on November 27, 2011 at 3:03 pm
    I’m looking for a way to do the following in After Effects 5.5:
    – I’ve dragged a clip into the seq-thumb to create a new sequence using clip’s duration
    – Using Alt+[ and Alt+] I’ve shortened my clip (adjusting the in/out points)
    (for example the clip was 30 seconds, and I’ve cut something from the start and something from the end, and now my clip is 20 seconds, having 5 seconds black at the beginning and the end of the sequence)
    Is there a shortcut to set the sequence duration to the new clip duration. Or either equal to the start or end point of my clip.
    I know how to do it manually, aligning my clip’s start point with the seq start (by pressing ‘[‘ while the clip is selected) and then use Cmd+K to set the duration to the clip’s end point. But I believe that’s way too many steps.
    Isn’t there an easier way using shortcuts or creating shortcuts for this?
    Or maybe something that comes close to this?
    thank you.
    I use:
    Hardware:
    MacBookPro 2.5GHz Intel Core 2 Duo. 4GB 667MHz DDR2 SDRAM
    L2 Cache 2MB – Bus Speed 8MHZ
    NVIDEA GeForce 8600M GT VRAM 512 MB
    Software:
    OS Version 10.6.7 (Snow Leopard)
    FCP7
    Adobe Production Premium CS5.5
    AVID MC5.5
    I own FCPX but refuse to use it.
    David Goodwin replied 11 years, 4 months ago 3 Members · 3 Replies
  • Brian Charles
    November 27, 2011 at 5:37 pm
    You can set the Work Area using the B and N Keys and then trim the Comp to the Work Area.
    Select the trimmed layer and press the i key on the keyboard to go to the layer’s In Point, then press the letter B to set the Beginning of the Work Area.
    Press the letter o to move to the layer’s Out Point and then press the letter N to set the end of the Work Area.
    Now right click in the area above the timeline and select Trim Comp to Work Area.
  • Flo De haan
    November 27, 2011 at 11:54 pm
    thank you.
    that was really helpful
    I use:
    Hardware:
    Software:
    FCP7
    AVID MC5.5
  • David Goodwin
    April 29, 2015 at 5:00 pm
    Thanks. That was helpful. Roughly the same question
