Activity › Forums › Adobe After Effects Expressions › Auto secondary movement (inertia/overshoot) in children layers
Fabian Brugger replied 4 years, 8 months ago 7 Members · 29 Replies
Jake Dickey
April 26, 2016 at 3:11 pmLike a boss! Thank you! This has been really helpful in learning how to reference other layers’ properties properly. I was actually able to figure out how to make it work on an older version of the classic “bounce” expression BEFORE someone added in the amp variable,
freq = 3;
decay = 5;ppos=thisLayer.parent.transform.position;
n = 0;
if (ppos.numKeys > 0){
n = ppos.nearestKey(time).index;
if (ppos.key(n).time > time) n--;
if (n > 0){
t = time - ppos.key(n).time;
amp = ppos.velocityAtTime(ppos.key(n).time - .001);
w = freq*Math.PI*2;
value + amp*(Math.sin(t*w)/Math.exp(decay*t)/w);
}else
value…but I couldn’t figure out how to make it work on the version of the expression that I had WITH the amp variable. Thanks for letting me pick your brain a bit!
Tim Drage
April 27, 2016 at 11:06 amThese are great and I too have been looking for something like this for ages, thanks!!!
Eduardo Oliveira
April 27, 2016 at 11:22 amWas glad to help, Guys.
anyways, just for the sake of people that end up on this thread in the future, i’ve collated the most revised versions below, so that people can use the right ones without having to re-read the whole thread.
(these are 2 different expressions, use the one that suits your needs)
//inertial children bounce (apply on "position")
n = 0;
amp = .04;
freq = 2.0;
decay = 3.0;ppos=thisLayer.parent.transform.position;
if (ppos.key(n).time > time){
n--;
if (n == 0){
ppos.velocity
t = 100;
}else{
}if (n > 0){
v = ppos.velocityAtTime(ppos.key(n).time - thisComp.frameDuration/10);value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
}else{
value
}//inertial children rotation (apply on "rotation", for dagling things like earrings, dreadlocks, pendants etc)
n = 0;
amp = .04;
freq = 2.0;
parv=clamp(ppos.velocity[0]*amp,-90,90)
n--;
if (n == 0){
ppos.velocity[0]
t = 100;
}else{
}if (n > 0){
v = ppos.velocityAtTime(ppos.key(n).time - thisComp.frameDuration/10)*-1;parv + v[0]*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
}else{
parv
Tim Drage
April 27, 2016 at 3:13 pmThanks again, having a play with this 🙂
Two things i’d like to try if i can get my head around it and/or if even possible:
* modifying to make it operate in world space to make chains of dangling things 🙂
* making it so that it doesn’t clamp at 90°, ie so that the thing can spin right round and dangle up if the object is descending… don;t actually know if that makes any sense vs how the expression works tho.Will post any edited versions i manage to do anything interesting with, tho maybe you or someone else might have an easy answer to the above? 🙂
Ricardo Martins
August 9, 2020 at 12:49 pmSorry to bother you, but is there a way to make it affect the children’s rotatio be affected by the parent’s X and Y positioning? I’m quite new to expressions, couldn’t figure it out
I’m trying to make some hair on a character move automatically with the head movement.
Is it possible to make it check for parent’s position and rotation as well?
Eduardo Oliveira
August 9, 2020 at 1:21 pmHey Ricardo, how are you controlling the hair at the moment? is it on puppet pins? or jsut a layer on its own?
Sami Bayley
September 14, 2021 at 3:19 pmI also would love to add a delay to this, I’ve got a layer parented to another “leader” layer. Said leader layer has some position keyframes, the inertia effect is working great, however, I’d like the child layer to also have some delay. I’m pretty new to expressions so am still trying to figure it all out!
What I’ve tried is using this expression:
delay = .03; parent.fromWorld(toWorld(anchorPoint,time-delay))
Along with adding this to yours:
//inertial children bounce (apply on "position") n = 0; amp = 4; freq = 1; decay = 4; delay = .03;
For some reason its just not doing what I want it to do!
Fabian Brugger
January 31, 2022 at 7:47 pmHey, is there anything we need to change for new versions of ae (22)? The position expression works perfectly but the rotation expression doesn’t work for me. No error, just doesnt more anything…
greetings
