auto scale problem
Hi all. I have a rig set up, ( project posted below ), and I know the problem but I haven’t figured out the solution.
I have a text layer followed by a precomp. ( this precomp will have a logo in it that will never need to be changed ). so for this example the precomp has a white solid in it.
I have set up the precomp to follow the text layer, so it will automatically move to the correct position.
I have another expression to auto center these 2 layers so they stay in the middle of the comp ( 1080 px ).
Then my final expression, is to force these 2 layers to auto scale down to never be longer than the safe title lines. ( I need to assume that the text layer might read something very long like ” Available mondays through fridays for free on”
this is where the other expressions are not working. the layers scale down but the position of the precomp moves continuously left as the the text scales down. I need the precomp to keep the relative distance from the precomp to the text.
Can anyone help me correct my first expression to take this into account ?
Thanks so much for any help
