Activity Forums Adobe After Effects Expressions Auto scale pictures proportionately to comp width/height
  • Auto scale pictures proportionately to comp width/height
    Posted by Eric Hartmann on July 29, 2009 at 7:10 pm
    I’m working on a project that requires me to have several pictures on the right side of a comp, then scale up to full res.
    Basically what I need is an expression that will have any size image scale proportionately to the comp’s size.
    Can someone help me with how I need to word it in the expressions dialog box?
    Dan Ebberts replied 17 years, 1 month ago 2 Members · 1 Reply
  • Dan Ebberts
    July 29, 2009 at 8:06 pm
    If you can drive it off one dimension, it could look like this:
    nominalCompHeight = 480;
    value * thisComp.height/nominalCompHeight
    Or, if you need independent x and y scaling, it would look like this:
    nominalCompWidth = 640;
    [value[0]*thisComp.width/nominalCompWidth,value[1]*thisComp.height/nominalCompHeight]
    You need to specify the nominal comp width and height values that correspond to a scale of 100%.
    Dan
