Activity Forums VEGAS Pro Auto Ripple Question
  • Auto Ripple Question
    Posted by Sergio Lelevier on March 17, 2006 at 5:58 am
    Auto ripple is working if I insert an event from the trimmer. But when I try to move an event within the
    same track between two other events, the event that I move stays on top of the event that should
    move to the right. Does auto ripple only work if you’re inserting from the trimmer?
    Edward Troxel replied 20 years, 6 months ago 3 Members · 5 Replies
  • Gary Kleiner
    March 17, 2006 at 6:31 am
    Are you letting go of the mouse to complete the edit? Everything will move then.
    In general, I recommend using post-ripple instead. It’s easier to control what’s going on.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Sergio Lelevier
    March 17, 2006 at 1:26 pm
    How do you switch from auto ripple to post ripple?
  • Sergio Lelevier
    March 17, 2006 at 2:32 pm
    I think solved the problem…If you are in auto-ripple you must move the event with the right click in the mouse, then it gives you the option to shuffle, move or copy the event.
  • Sergio Lelevier
    March 17, 2006 at 2:39 pm
    Nope! you can also do this in override.
    Ripple is evil in Vegas!
  • Edward Troxel
    March 17, 2006 at 3:00 pm
    [tjglfr1] “move the event with the right click in the mouse, then it gives you the option to shuffle, move or copy the event.”
    This is actually a different option.
    To turn Ripple off, simple click the ripple button on the toolbar. Then you have to use the keys (F, Shift-F, CTRL-Shift-F) to control rippling AFTER the event is moved. Do a search for “post ripple edit” in the help file.
    Edward Troxel
    JETDV Scripts
