Activity Forums Adobe After Effects Auto Re-Sizing Text Boxes (FIXED HEIGHT) using sourceRectAtTime
  • Auto Re-Sizing Text Boxes (FIXED HEIGHT) using sourceRectAtTime
    Posted by Fabio Basone on May 15, 2018 at 3:25 pm
    Hello
    I’ve been using the sourceRectAtTime expression to create some auto-resizing text boxes for a template I’m creating
    But i’ve run into difficulties when using accented letters (i.e. ¿CÓMO ESTÁS?) because it changes the heights of the box
    I need t keep a fixed height regardless of whether I use accented letters or overhangs (J) or underhangs (y).
    I also need the space/leading between each line of text to remain constant and not vary depending on what letters I enter.
    Basically, how do I fix the height of the text boxes and only have the width variable? I’ve attached some screenshot to illustrate the problem.
    Many thanks for your help
    FB
    Kalleheikki Kannisto replied 8 years, 4 months ago 3 Members · 4 Replies
  • Kalleheikki Kannisto
    May 15, 2018 at 4:00 pm
    Accents should not in any way affect line spacing.
    I would simplify the matter by parenting the shape layer to the text layer (if you need to move the texts around), then aligning the anchor point to the origin point of the text layer. This way you can calculate the width of the box directly and it will scale around the right point without having to calculate the anchor point position. For fixed line height, you can use a constant rather than calculating it. Or, if you have the need for multi-line texts, you can round the height to closest multiple of that constant.
    The matter will be more complicated if you need different type sizes.
    Senior Graphic Designer
  • Walter Soyka
    May 15, 2018 at 5:38 pm
    If you want to fix the height, replace this line:
    var h = s.sourceRectAtTime(mid).height;
    with this line:
    var h = 89;
    … in both the size and position expressions.
    (That values comes from the evaluation of that expression in the UI.)
    The downside of course is that the expression will no longer react to changes to the size of the layer. If you adjust the size of the type, you’ll also have to adjust the expression.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Fabio Basone
    May 16, 2018 at 11:44 am
    Hi
    Thanks for your help – unfortunately, it doesn’t seem to work
    Now the position of the box shifts
    Any of other ideas?
    May 16, 2018 at 6:18 pm
    If you disable the position and anchor point expressions and use parenting instead, with aligned box and text layer anchor points, that will take care of the position.
