Activity › Forums › Apple Motion › Auto Orienting to Camera
  • Stephen Smith
    July 15, 2009 at 6:25 pm
    Put it in its own group and make the group 2D.
    Lone Peak Productions
    Check out the TV Show Open I did.
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
  • Doyle Rockwell
    July 16, 2009 at 9:54 pm
    Howdy,
    If you’re referring to an object that has a position in 3D space but always faces the camera, you can achieve that by applying the Point At behavior to the object. In the behavior’s settings, set the camera as the target and set the Transition value to 0% (which means that it won’t turn to the camera over time, but immediately/always be facing the camera).
  • Nathan Trenkamp
    July 16, 2009 at 10:22 pm
    Excellent! That’s what i needed to know. Thanks Jim!
