Activity Forums Apple Motion Auto orient?
  • Auto orient?
    Posted by Bret Williams on April 28, 2015 at 8:37 pm
    As I realize I’m still learning to do what I’ve known how to do in AE for years I have another question…
    How do you auto-orient objects along a path? For example I have a car driving along a curvy path/road and I’d like it to always face the direction it’s traveling, turning appropriately as the path turns. In AE it’s called auto-orient along path.
    Robin S. kurz replied 11 years, 4 months ago 3 Members · 3 Replies
  • Mark Spencer
    April 28, 2015 at 8:50 pm
    Add the Align to Motion (Simulation) behavior.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Bret Williams
    April 28, 2015 at 8:59 pm
    Excellent I’m on the right path as I just figured that out (snap alignment to motion, correct?) EXCEPT, it turns my car 90degrees and it points the side of the car down the path. Perfectly sideways however. It seems to override the actual rotate controls. In AE, auto orient is similar to an “add” parameter. It orients it, but if you’ve adjusted the rotation yourself, it adds the info together.
  • Robin S. kurz
    April 29, 2015 at 9:16 am
    I’m assuming you have the rotation axis set to Z? But if you don’t want to edit the graphic accordingly, then simply apply both behaviors to the group that the car is in and position, scale, rotate etc. as needed within the group.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
